Octolapse "Printer Not Primed" with 0.8mm Nozzle
Delarado
(@delarado)
Hi Guys,
Just changed to a 0.8mm nozzle and now nothing will print, it fails with the error message:
Gcode Processing Failed
Printer Not Primed
Priming was not detected.
If I turn Octolapse off, I can print ok.  No matter what I set the "Layer change detection priming height" To, the print won't start.
I'm using a 0.4mm layer height.
I've tried setting the layer change detection priming height to:
0mm
0.1mm
0.4mm
0.41mm
0.45mm
0.8mm
0.85mm
1mm
This is strange, as setting it to 0mm should turn it off I thought? Has anyone else experienced this?
Thanks
Veröffentlicht : 14/01/2021 5:30 pm
Delarado
(@delarado)
RE: Octolapse "Printer Not Primed" with 0.8mm Nozzle
Seemed to be something wrong with the sliced GCODE - I completely closed everything and re-sliced it and it worked ok!
Veröffentlicht : 14/01/2021 6:03 pm
01Pad
(@01pad)
Printer not primed error in Octolapse
Hi there.
I have an i3 Mk3S and use a 0.6 nozzle with a 0.46 layer height.
I've had the same problem, and can't get a print to start unless I disable Octolapse, with the same error message as you reported.
I also tried setting Priming height to 0 as they suggest, to turn it off, but it won't allow me to save that value, and highlights it in red as an unacceptable setting.
I am working my way through various priming height settings to see if it will work, and I've put a help request about it in the Octolapse section on Github.
If I hear anything I'll let you know.
Veröffentlicht : 28/09/2021 9:46 am
