Octolapse "Printer Not Primed" with 0.8mm Nozzle
Hi Guys,
Just changed to a 0.8mm nozzle and now nothing will print, it fails with the error message:
Gcode Processing Failed
Printer Not Primed
RE: Octolapse "Printer Not Primed" with 0.8mm Nozzle
Seemed to be something wrong with the sliced GCODE - I completely closed everything and re-sliced it and it worked ok!
Printer not primed error in Octolapse
Hi there.
I have an i3 Mk3S and use a 0.6 nozzle with a 0.46 layer height.
I've had the same problem, and can't get a print to start unless I disable Octolapse, with the same error message as you reported.
I also tried setting Priming height to 0 as they suggest, to turn it off, but it won't allow me to save that value, and highlights it in red as an unacceptable setting.
I am working my way through various priming height settings to see if it will work, and I've put a help request about it in the Octolapse section on Github.
If I hear anything I'll let you know.
