Meshmixer for Linux?
jsw
 jsw
(@jsw)
I'm putting this in a more specific sub-forum.
I've seen references that Meshmixer is available for Linux, but I've been unable to find it.  Web searches find references to it, but so far no actual image.  I've tried installing the Windows version under Wine, but it simply hangs during installation.
Does anyone who uses Linux have a working Meshmixer?
Thanks.
Opublikowany : 26/05/2020 4:02 pm
vintagepc
(@vintagepc)
RE: Meshmixer for Linux?
I've successfully installed it using Crossover.
YMMV though - It launches fine and appears to work but I've never really done any in depth work on it. (Though I do also run F360 without any major issues, if that's any indication)
Opublikowany : 26/05/2020 4:19 pm
jsw
 jsw
(@jsw)
Thanks.
I don't have Crossover installed, but I may try that if it's indeed true that there's not a native Linux build.
Opublikowany : 26/05/2020 4:48 pm
vintagepc
(@vintagepc)
I doubt there is. It probably went the way of the dodo when it was bought by Autodesk; they have no interest in Linux support for their products
The packages you are seeing references to are probably years out of date.
Opublikowany : 26/05/2020 5:13 pm
