How to combine models for multi-material printing?
ecc
 ecc
(@ecc)
I've prototyped separate components that I'd now like to combine into a single, multi-color object. I only have a single-material printer, so I'm hoping to use a 3D printing service to make it. The geometry is simple -- a flat box in one color, with some raised decorations on the top in another color. What's the best workflow for this (ideally on Linux)?
Publié : 25/10/2021 6:34 pm
jkavalik
(@jkavalik)
Membre
RE: How to combine models for multi-material printing?
You can configure PrusaSlicer as if you had a multimaterial printer, load the object parts, see if it is ok and if it can be sliced the way you want a then just export "project" to 3mf.
Publié : 20/11/2021 5:44 pm
