Dual extruder support improvements
I just set up an IDEX machine and in Prusa Slicer when printing with a support material on the second print head it passes through the part and drags dissolvable support material over the part when it could easily avoid it.
Even worse if I enable do not cross perimeters it goes out of it's way to drag the support print head into the perimeter of the part and drag it through the part as much as possible.
I guess first I should ask if there is a way to change settings so that the support material head stays out side of the perimeter as much as possible. And if not it would be really nice if this issue was addressed.
Postato : 14/08/2022 7:50 pm
