Can the Prusa slicer do area restricted in-fills?
Johnno
(@johnno)
Hi Everyone!  I'm trying to achieve this:
Is there any way to have the Prusa slicer only use an in-fill percentage over a certain region of the STL model?  But then use a solid in-fill for the remainder of the part?  How would I go about doing this?
Best Answer by Diem:
Yes use modifiers. Right click on the part, add modifier, place it where required then right click on the modifier and one option is to define the local infill.
Postato : 18/05/2021 6:31 pm
RE: Can the Prusa slicer do area restricted in-fills?
Postato : 18/05/2021 7:21 pm
1 persone hanno apprezzato
Johnno
(@johnno)
Perfect, thanks Diem!  I wasn't aware of the ability to add modifiers like this.  By setting the STL to 20% in-fill and then adding two cylinder modifiers over the ends and bumping their infill level up to 100%, I get exactly what I was after.  😊
Here's a virtual beer for you 🍺.
Cheers!
Questo post è stato modificato 5 years fa 3 tempo da Johnno
Postato : 18/05/2021 8:10 pm
