Calibration banging bed
SteveS
(@steves)
Very wary of updating the firmware as, to be honest, I don't really trust it! Print quality took a hammering after one upgrade...
However, starting to get very tired of the bed banging its X and Y end stops at the start of every print. Calibrating?
Does the latest firmware aaddress this? Also the issue of the filament error reporting (MK4 thing?) after every print!
Opublikowany : 13/05/2025 11:53 am
TommyCat
(@tommycat)
RE: Calibration banging bed
Since the motors dont have an encoder for their absolute Position a calibration is necessary. ItS the same one my Core one. So dont worry about that.
Opublikowany : 20/06/2025 9:09 pm
Rebecca Nelson
(@rebecca-nelson)
Yes. Indeed, the newer firmware reduces the sharp knock when stopping and improves the operation of the filament sensor. Of course, if you have an older version, then the update should solve the problems.
Opublikowany : 26/11/2025 11:05 am
Marcel
(@marcel-7)
Optimising the belt tension with the "belt tuner" https://belt.connect.prusa3d.com/ helped mine a lot for getting a faster and better calibration resulting in less banging.
Opublikowany : 18/12/2025 5:56 pm
