buddy-prometheus-exporter output format
_KaszpiR_
(@_kaszpir_)
Hey, anyone able to provide example output for the buddy-prometheus-exporter for the newest version (I guess that requires prusa mini 5.x alpha firmware, but if you have older version compatible with 4.x then it is also okay)?
I'm interested in text output used by prometheus for scraping especially if the printer is printing or not (to see how certain metrics change). I believe you should create a file and attach it to the post.
What I want to do is to adjust my custom config for  json-exporter to expose metrics in the same format as buddy exporter. I have already working example with it but I bet outputs are incompatible. As a result I'd like to use the same dashboards in Grafana with the same metrics, if possible.
Posted : 01/11/2023 7:51 pm
