3mf files from Bambu Studio
Blackadder
(@blackadder)
Hi all, does anyone know if we can covert 3mf files that were created using Bambu Studio into Pruserslicer. Apparently, as of October 17, 2023, Bambu .3mf files cannot be opened in other slicers, including PrusaSlicer.
Napsal : 24/11/2024 3:45 am
Fred
 Fred
(@fred-13)
RE: 3mf files from Bambu Studio
Not a definite solution.  I have the same issue.  In my situation is was the problem with files that had text added to them.  I was adding text to models to identify the model for future printing.  None of the Bambu Labs files with text would open in Prusa slicer.  When I removed the text the files opened just fine.  I just had to recreate the text in Prusa slicer.  I have no issues opening the files from Prusa slicer in Bambu Studio.  I contacted Prusa tech support and they could not find a solution to the issue.
Napsal : 12/04/2025 10:55 pm
It appears to be a cynical ploy - Bambu use Prusa's open source software, badge it as their own and tweak it slightly so that, apparently deliberately, the files cannot be used on Prusa; this appears to be an attempt to restrict certain files for their own exclusive use.  Afaict it's always possible to export from Bambu Studio in a form  that Prusa Slicer can import but settings are lost.
Napsal : 13/04/2025 7:04 am
Fred
 Fred
(@fred-13)
I received this suggestion from CinderWing3D who I purchase 3D models from.  It worked perfectly for importing her Bambu Studio colored models into Prusa slicer to print with my Original XL 5 tool printer.
Generally the issue lies in the splitting to objects part. As Bambu and Prusa handle it separately. I recommend loading in the 3mf, and when it prompts about "Multi part object detected" to click NO. It will load them onto the bed in pieces but you can CTRL+Z and undo the auto arrange and then it loads in perfectly!
Hope this helps.  I have not seen this solution offered anyplace else I researched and it worked for me as long as the file does not error during import.
Napsal : 13/04/2025 11:25 pm
RaistlinJ
(@raistlinj)
I created a converter here:  https://github.com/raistlinJ/3mf_bambu2prusaTested with several models and it seems to work; even transfers painted objects.
Hope it helps.
Napsal : 09/08/2025 8:14 pm
RaistlinJ
(@raistlinj)
Sorry, correct link is:   https://github.com/raistlinJ/3mf_bambu2prusa
Napsal : 10/08/2025 8:54 pm
Kronr
(@kronr)
I struggled with this for a while, even tried the above GITHUB python script, which was a pain in the ass for me.  Then I figured it out, after you open the Bambu created 3mf file in PrusaSlicer, all you need to do is right click on the file on the right hand side , hover over Change Extruder, and select Extruder 2.  This fixed the coloring for me.  I tried a few files and this worked for all of them.
This post was modified před 6 months 2 times by Kronr
Napsal : 02/01/2026 8:43 pm
