Where is the downloaded file
ChiTownGuy
(@chitownguy)
If I "direct upload" to my MK3 without checking the Start Print after Transfer" where is the file stored so i can print it later?
Postato : 05/01/2023 8:55 pm
Tojik
(@tojik)
Utenti Moderator
Hi, the files should be under /home//PrusaLink gcodes. You should be able to access it through the Connect or PrusaLink web file browser. If anything doesn't work for you, please let me know.
Postato : 05/01/2023 10:05 pm
ChiTownGuy
(@chitownguy)
RE: Where is the downloaded file
I found it in the projects tab or the Prusa Link interface.  I was trying to print from the LCD and it's not stored on the sdcard plugged into the einsy but rather on the micro SD card plugged into the RPI Zero 2 W.
Postato : 05/01/2023 10:21 pm
Tojik
(@tojik)
Utenti Moderator
Exactly, there is no way for me to reliably influence the printer menu, so I cannot write your folder structure in there
Postato : 05/01/2023 10:23 pm
ChiTownGuy
(@chitownguy)
Is there any way that a future version of the Prusa MK3 firmware can access the files on the PrusaLink system so that the files can be selected from the Prusa LCD menu?  I realize this would require firmware changes on the Einsy.
Postato : 09/01/2023 2:10 pm
