What do I think of Prusa Connect? Answer: 500 Internal Server Error
SeattleDavid
(@seattledavid)
Unreliable. Frustrating. Error prone. Just doesn't work.
I have purchased a lot of Prusa products over the years. Something bad seems to be happening inside of Prusa these days. Perhaps the programmers think they are "rock stars" instead of thinking they are programmers?
Posted : 07/10/2023 2:47 pm
Qubiki 3D
(@qubiki-3d)
I have the same. I cannot use the prusa connect system. atm I am using transfering files via SD Card to my MK3S+ machine and with usb sticks to MK4 Machines. All the time I have offline. Or it will log me out then log in. Saying I dont have Permision to view prusa connect.
If there would be a change to host own Prusa Connect system on localhost server. I dont want use Octoprint. But If I must I will change to Octoprint my little farm
This post was modified 2 years ago by Qubiki 3D
Posted : 07/10/2023 2:53 pm
Qubiki 3D
(@qubiki-3d)
RE: What do I think of Prusa Connect? Answer: 500 Internal Server Error
The issue is HTTP Error 5xx on my all Prusa Link Machines
Posted : 07/10/2023 3:14 pm
Patrick.b
(@patrick-b)
same here ...try to use the 2 factors authentication seems ok after !!
Posted : 07/10/2023 5:01 pm
Tojik
(@tojik)
Member Moderator
Could you guys share any more technical details? Seems like the 2FA status might be useful. Any other relevant info you think might help to find the cause?
Posted : 09/10/2023 11:29 am
Tojik
(@tojik)
Member Moderator
It's nice to read to go screw off in the morning, but we actually need to resolve the issue lol 😀 Thanks patrick for the possible workaround
The team moved the whole backend between cloud providers. That by itself can create new problems. Sorry for the disruption
Posted : 09/10/2023 11:32 am
Qubiki 3D
(@qubiki-3d)
When I was using the login was acting weird. It was login and login out and on my 3 printers i had the same error if i remmember it was http error 5xx on two mk4 and on one Mk3s with raspberry
Posted : 09/10/2023 12:46 pm
