UI improvements
UI improvements
Can we make that second top nav bar (Dashboard Printer Files Print Queue etc) fixed, so it won't scroll off, with the white space between it and the black bar above it reduced? I find that going between the options on this nav bar is what I do seem to do most, and half the time the bar has scrolled off.
Opublikowany : 11/02/2024 12:34 pm
STEAMlab
(@steamlab)
RE: UI improvements
Additional request:
In the printer file view, add checkboxes beside each file and then a delete button at the top of the list (like the Prusa Connect file list) to bulk mark and delete files. Right now you have to manually right click, choose delete, and confirm on each file to delete it from the printer. This is time consuming!
Opublikowany : 05/03/2024 5:18 pm
RE: UI improvements
|Making suggestions like this on prusa slicer github. saves time
Opublikowany : 05/03/2024 7:35 pm
Tojik
(@tojik)
Member Moderator
RE: UI improvements
Hi, if printer file bulk delete was easy to do right, it would already be in Connect, sorry about that. I have asked about the top bar scrolling off, maybe it's time to bring that up again
Opublikowany : 07/03/2024 10:22 pm
