Graphic interface ? Prusa-Link
CNC24/7
(@cnc247)
Hello Guys 🙂
Someone try it to connect an Touchdisplay to the Raspberry to have a graphic interface like Octodash ? or is it no way to use this ?
Has Prusa-Link a graphic interface ?
This topic was modified 3 years ago by CNC24/7
Posted : 27/12/2021 4:46 pm
DanielAttia
(@danielattia)
RE: Graphic interface ? Prusa-Link
There is some control/graphics if you access the Prusa-Link locally.
While it would be nice to be using something like Octodash, I assume that they are currently prioritizing PrusaConnect.
Posted : 27/12/2021 7:57 pm
CNC24/7
(@cnc247)
So you mean if i connect a Touch Display to the Raspberry i will have a Graphic Interface?
If the Doing it like the Octodash would be very nice 🙂
Posted : 27/12/2021 8:18 pm
DanielAttia
(@danielattia)
No, a Raspberry Pi with PrusaLink will not show you anything if you connect a display to it. As the intended use case is for a RasPi Zero W to be connected to the printer inside of the Einsy RAMBo case.
PrusaLink creates a web server on your local network that will show you some controls similar to OctoDash.
Posted : 27/12/2021 11:26 pm
