Slack notifications customize text
sept1x
(@sept1x)
I have set up Slack notifications in Prusa Connect and it is working. But the text messages are in english and quite wordy. I want to shorten some of the text and if possible also translate them to another language. Are there any settings or config files available to do that?
Here are some things I wish could be removed or changed:
- remove "Remove the printout from the printer and prepare the printer for the next job." in the finished print notification
- shorten "Printer has started printing the job" to "started"
- shorten "print job <filename> was finished" to "<filename> finished"
- shorten "It should be completed in <time>" to "completes in <time>"
Opublikowany : 07/03/2024 9:17 pm
sept1x
(@sept1x)
RE: Slack notifications customize text
BTW why is is required to log in to even view posts and replies in this subsection of the forum?
Opublikowany : 08/03/2024 8:57 am
Tojik
(@tojik)
Member Moderator
I think it's misconfigured from the beta days
Opublikowany : 08/03/2024 6:18 pm
sept1x
(@sept1x)
Someone has changed it so the forum section is visible without login now, thank you 🙂
Does any person have an answer to my original questions?
Opublikowany : 18/03/2024 9:36 pm
1 ludzie polubili
Tojik
(@tojik)
Member Moderator
I brought up the notifications, it will get some attention hopefully soon.
Opublikowany : 19/03/2024 11:16 am
