Select Filament For MMU Remotely
ASPRINT
(@asprint)
Hello,
I just connected my Raspberry Pi 3 to PrusaConnect and PrusaLink today. I own an i3 MK3S+ with a MMU3. I was using the single material feature and was wondering if there was a way to select which filament I wanted to use for the print remotely. Thanks!
ASPRINT
ASPRINT-(Proudly)MK4S MMU3 Owner
Publié : 08/03/2024 12:06 am
Tojik
(@tojik)
Membre Moderator
Hi, sorry there's not. In the filament selection screen, the printer stops responding to commands. You would have to modify the gcode to use the appropriate T command to load the filament you want and remove the one which asks you which one you want. Then the purge still requires user interaction and there are no plans to automate that. Sorry, there are no plans to improve that on the MK3 generation
Publié : 08/03/2024 6:17 pm
ASPRINT
(@asprint)
RE: Select Filament For MMU Remotely
Hey @tojik,
I put in a feature request to Prusa. Hopefully, it will work.
ASPRINT
Publié : 08/03/2024 9:53 pm
Tojik
(@tojik)
Membre Moderator
Great, you have reached me. Just another way. It's not that I want to block your feature request, we have gone over the possibility of such feature with the FW team before. Unfortunately this feature will not exist on the older style printers unless something extraordinary happens. Sorry about that
Publié : 08/03/2024 10:41 pm
ASPRINT
(@asprint)
This makes me very sad because there is no point in PrusaLink or PrusaConnect if MMU users cannot select filament remotely. However, I understand where the FW team is coming from (I am a coder myself) and I just wish there was a way to make this work.
Publié : 09/03/2024 9:51 pm
Tojik
(@tojik)
Membre Moderator
You can probably work around this by slicing on the full mmu profile and using only a single material. Or is there a problem with doing that? Does it still print the wipe tower? Or does it get by "wiping" to infill?
Publié : 11/03/2024 11:57 am
rosal02
(@rosal02)
Membre
Hello together. I had the same problem when selecting the "MMU3 Single" Profile in PrusaSlicer. Now I just have to select the normal "MMU3" Profile and coloring the whole Model in one Color and selecting the extruder. So I can confirm that the Purge Block will not be Printed and when you press ready in PrusaConnect the Printer starts automatic and select the right filament from the MMU3.
Hope this helps 🙂
Publié : 13/03/2024 6:57 pm
1 personnes ont aimé
Tojik
(@tojik)
Membre Moderator
Thank you for confirming this
Publié : 13/03/2024 6:59 pm
DÆSIGN
(@daesign)
Membre
Hi everybody!
I've read your thread, and it is to bad about the mk3s+.
But I can say this:
Just recently I upgraded mine to a MK3.5 and the MMU2s i had to a MMU3.
Except for the X axis failure of calibration and a little trial and error to get the right nozzle temp to melt enough filament, I am really happy with the improvements.
Well worth it for the speed and convenience of the new Buddy board 🙂
Back to topic:
How about choosing the correct tool on the MMU3 from Prusa Connect to do a single-filament print?
Is that something that will be in the future for the MK3.5/MK3.9 and MMU3 combo?
Also, I can't seem to figure out just exactly how I can start a print with pre-defined and pre-loaded materials in Prusa Connect.
It seems like I have to use the LCD on the printer no matter what I do to the settings in PrusaSlicer.
Publié : 23/03/2024 10:18 pm
Tojik
(@tojik)
Membre Moderator
Hi, that'S weird, for normal non mmu prints, this should be as straightforward as hitting upload and print. What exactly do you have to do on the LCD that is stopping you from printing from PrusaSlicer alone? Thanks
Publié : 25/03/2024 12:07 pm
Ankerman
(@ankerman)
Membre
resurrecting this thread.  I also upgraded to the MK3.5 + MMU3 combo, and moved to Prusalink/Connect after having used Octoprint before. One feature I really liked was the MMU2 Filament Selector plugin ( https://plugins.octoprint.org/plugins/mmu2filamentselect/).
Do I understand correctly that this is not possible within Prusaconnect because it would need inline gcode modification by the firmware? With the above plugin Octoprint takes care of this I believe.
Thanks
Publié : 11/09/2024 6:14 am
Larswa
(@larswa)
Same boat. Mk3.5 / MMU3, Prusa connect/Link and also used to rely on the MMU2 filament selector plugin for Octoprint.
I can confirm that just using the standard MMU profile and painting it with the color of the filament I want to use, works just fine. I dont see a need for me, for selecting filament when starting printing. I could just slice the model again and select another filament. Not a big deal, for me at least.
Publié : 09/10/2024 12:05 pm
Ankerman
(@ankerman)
Membre
Indeed, this is what I am doing now as well.
Publié : 09/10/2024 1:34 pm
joseraulrivera
(@joseraulrivera)
Membre
The problem with slicing with a multi-material profile instead of a the single is that for items where the material type matters, when you've changed which feed the materials are in, you need to reslice and push the new item.
When printing the same item numerous times, consider hundreds of prints, being able to select from the items in PrusaConnect save time and effort from a production perspective as well as management of the files in PrusaConnect and on the printer.
This does not need a firmware update, OCTOPrint has a plugin that lets OCTOPrint do this.  Given that, it means it can be a software update to Connect/Link.
It's disappointing that you are not considering this, as this impacts anything using MMU and Connect (MK4/CORE One), which are your new printers.
Regards,
José
Publié : 02/01/2025 3:04 pm
Badger
(@badger-3)
Membre
After brief look in the OCTOPrint plugin I think it's modifying the gcode prior sending it to the printer, maybe that might be the way for Prusa Link as well. I'd say it shouldn't be "that costly". As an official developer does not see a point in supporting in my eyes quite importatant feature. Admit it, our combo is slowly getting obsolete. I wonder if we can do some dirty hacke.. e.g. some patching of the PrusaLink app on the RPi. It really slows things down for me. From time to time I just want to reprint older gcode (where I manually edited things like support or slicer settings and of course I don't have it saved). I'd like to do it remotely and usually with a different filament that's loaded in position that's hardcoded in the gcode.
Anyway stop ranting and start thinking:
I suppose it should be quite easy task to modify  the extruder order hardcoded in the gcode. I'd say it should be one of the dask doable doable with sed in command line, but I have no idea how the MMU is driven out of the gcode. Maybe topic for another long evening.. to bad I don't have much time lately.
Publié : 09/12/2025 11:48 am
