Reflash and update
DNELMS
(@dnelms)
Reflash and update
I was trying to piece together the process of reflashing/updating all three of my prusalinks rasPi's but the information I found seemed a bit scattered so before I try this I thought I would ask; Is there a guide to this process that perhaps I overlooked?
Napsal : 24/04/2023 8:45 pm
Tojik
(@tojik)
Member Moderator
RE: Reflash and update
Sorry, no update process yet, only a full re-flash with some options to not lose all settings. Please do not update if you're on the 0.6.1 the issues are Connect side. The beeping is now real bad and would force you to turn off all your printer sounds. The 0.7.0 RC4 will have beeping off by default.
There is an update button now. There will be updates that do not require a full re-flash, but there might still come some that do.
Napsal : 24/04/2023 9:39 pm
1 lidem se líbí
Patrick.b
(@patrick-b)
Tojik
do you know if it's same beeping problem when the printer is connected via usb/RJ45 with the rpiow2 linked to the rambo ? or only wia Wifi ?
at today i don't understand i have linked, not linked linked not linked..........with prusa link?? and my wifi works perfectly
Napsal : 25/04/2023 8:29 am
Tojik
(@tojik)
Member Moderator
Connect is having a bad time, difficult to tell what is causing what. But the exact wording linked, not linked would suggest something I've never seen happen, so assuming it's just a coincidence.
Napsal : 25/04/2023 9:23 am
Patrick.b
(@patrick-b)
well i was meaning the rpiow2 insert w gpio to the rambo ..:-) and then adding usb/rj45 to the ethernet is also beeping..!!
Napsal : 25/04/2023 9:31 am
Tojik
(@tojik)
Member Moderator
Yes, everything is beeping. There's no escape
Napsal : 25/04/2023 10:32 am
1 lidem se líbí
DNELMS
(@dnelms)
Ok, thanks for that word of warning. I should wait for at least RC4.
Napsal : 25/04/2023 11:52 am
