PrusaLink lock-up
Agkirk
(@agkirk)
PrusaLink lock-up
When I attempt to access Prusa Link via ip address I can't get past the credentials. Either I have forgotten something or there is another problem.  I cannot recover from this problem.  Is there a way to reset the password?
Opublikowany : 23/10/2023 10:16 pm
_KaszpiR_
(@_kaszpir_)
RE: PrusaLink lock-up
What printer do you have?
In Prusa Mini+ go to Settings > Network > PrusaLink and ond the bottom there is a current API key.
Opublikowany : 24/10/2023 6:32 am
Tojik
(@tojik)
Member Moderator
Also, make sure your printer is showing the main menu. Iight have seen a bug describing it being broken in the wizard and such
Opublikowany : 24/10/2023 12:23 pm
Agkirk
(@agkirk)
I solved my issue using hints presented in links on this channel.
I never got the PrusaLink to work with my Mk3S RPi Zero W using PrusaOS.
I did get the PrusaSlicer wireless file transfer working (slowly at serial transfer speed) by using PrusaConnect and https://connect.prusa3d.com with the API I got from the Settings drop down for my MK3S printer in Prusa Connect. I put this data in the drop down for Add Physical Printer in the Prusa Slicer.
Hope this helps someone else.
Opublikowany : 26/10/2023 9:01 pm
