Prusa Link throws "bad magic number" error
bux024
(@bux024)
Hello folks,
as my printer is sitting right next to my homelab machine, I'm trying to set up Prusa connect to connect my homelab to the printer via USB.
However, I'm currently stuck at installing Prusa connect.
Things I've done so far:
1. Set up a fresh Ubuntu 22.04.3 instance + sudo apt update/upgrade
2. Installed neccessary stuff as advised on the Prusa Link GitHub page
sudo apt install git python3-pip libcap-dev libmagic1 libturbojpeg libatlas-base-dev python3-numpy
3. Installed Prusa Link with pip as advised on the Prusa Link GitHub page
pip install PrusaLink
While installing, pip threw the following warnings:
 WARNING: The script unidecode is installed in '/home/username/.local/bin' which is not on PATH.
  Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location.
  WARNING: The scripts pip, pip3, pip3.10 and pip3.11 are installed in '/home/username/.local/bin' which is not on PATH.
  WARNING: The script docutils is installed in '/home/username/.local/bin' which is not on PATH.
  WARNING: The script normalizer is installed in '/home/username/.local/bin' which is not on PATH.
  WARNING: The scripts prusalink and prusalink-manager are installed in '/home/username/.local/bin' which is not on PATH.
Therefore, the command "prusalink" does not work (command not found).
After some googleing, I found this thread on stackoverflow stating the identical issue with another application.
As I'm not very familiar with python, is just copy/pasted the following code from stackoverflow:
echo "export PATH=\"`python3 -m site --user-base`/bin:\$PATH\"" >> ~/.bashrc
source ~/.bashrc
After that, the "prusalink" command throws the following error:
username@prusalink:~$ prusalink
Traceback (most recent call last):
  File "/home/username/.local/bin/prusalink", line 5, in
    from prusa.link.__main__ import main
ImportError: bad magic number in 'prusa.link': b'a\r\r\n'
And thats where I'm currently stuck as I do not know how to proceed to get this problem solved.
Any help is much appreciated!
Many thanks in advance.
Best Answer by Tojik:
Please install straight from github instead - the lower section. For some from my perspective dumb inexplicable reason, the pypi version is a binary distribution and not a source distribution meaning you'll need the same python version to the one it was built with to run it. I will attempt to make the person who made the pypi package consider doing that. Thanks for the report
This topic was modified 12 months ago 2 times by bux024
Posted : 16/10/2023 3:55 pm
Tojik
(@tojik)
Member Moderator
RE: Prusa Link throws "bad magic number" error
Posted : 16/10/2023 4:21 pm
bux024
(@bux024)
Thanks for the hint.
Installing directly from github works like a charm.
source ~/.bashrc
is still required when using Ubuntu.
Maybe add a note to the install section regarding the pypi topic.
Many thanks and have a nice evening.
This post was modified 12 months ago by bux024
Posted : 16/10/2023 5:12 pm
Tojik
(@tojik)
Member Moderator
Didn't install on ubuntu, didn't know
Posted : 16/10/2023 5:16 pm
Tojik
(@tojik)
Member Moderator
What, that was a malformed message. So anyway. It should be fixed now. We didn't have the binaries for every python version in use. We do now, so it should start working normally. Thanks and sorry for the clearly unfinished message i've sent
Posted : 30/10/2023 6:05 pm
bux024
(@bux024)
No worries! Thank you very much for looking into this issue. I really appreciate the work you’ve put into this.
Posted : 30/10/2023 11:11 pm
Tojik liked
