Prusa connect mobile application
Henry
(@henry-4)
Hi, everything is great and i am wondering if there is a mobile app in the pipeline? Otherwise it can do like octoprint, some devs used the api to build their own app, can we do that?
Opublikowany : 29/12/2021 12:51 pm
Timo
 Timo
(@timo-2)
If you are using an iPhone you can open https://connect.prusa3d.com/ in safari.
Then click the share button (down in the middle) and choose 'Add to Home Screen'
I renamed it from 'Connect' to 'Prusa Connect'
I'm assuming there is a similar procedure available for Android devices.
I have no special talent. I am only passionately curious
Opublikowany : 30/12/2021 12:18 am
Henry
(@henry-4)
RE: Prusa connect mobile application
Yes but thats not optimal. I don't want to login each time and also the UI is not great on web mobile. I used octoprint for years and the same fonctionalities should be present since its good but the main problem with octoprint its not great for multiple printers (farm). I own 4 prusas and it's just what i think would be great for me. I like it so far, if the routes can be called with the api key devs could create their own apps.
Opublikowany : 30/12/2021 12:27 am
Phil @PhilthyFilaments
(@phil-philthyfilaments)
I'm using a plugin in octoprint that connects it to the apple watch and iphone. which is nice when the print finishes I get a notification, I can also view my print, and some minor controls as well
Opublikowany : 30/12/2021 6:50 pm
