Prusa Connect API for automation
I'm looking for a way to automatically read jobs in the Prusa Connect queue and start them from external software. Is this possible? It looks like prints can be externally loaded and started through Prusa Link, but this bypasses the queue system in Connect.
RE: Prusa Connect API for automation
Hello,
I'm also interested in
From hacky tests, I'm able to change the printer status on connect, thus triggering the queue, by posting to the connect/app/printers/YOURPRINTERID/commands/sync?
payload is {"command" : "SET_PRINTER_READY"}
you need to send your SESSID cookie with the request for authentification.
Doing that, I can run a local script which retrieves the job status from prusalink and triggers the queue on connect when print is finished. Obviously, the bed needs to be automatically unloaded in the meanwhile.
That said, it would be amazing to have a proper way to do this. Is there documentation anywhere?
Would also be great to be able to run connect locally, or simply implement the queue feature in prusalink. I find connect adding so many layers which are, in my humble automation case, really not needed.
There is PrusaConnect SDK in python but it exposes only a fraction of API and it can be used to simulate a printer https://github.com/prusa3d/Prusa-Connect-SDK-Printer
There is also PrusaLink API available but this is also just a printer spec.
PrusaConnect API spec was not published anywhere AFAIR, so only hacking and reverse engineering is the only way now.
Looking for the same, a proper documented API for PrusaConnect. Wasn‘t successful yet - maybe you know a way how to check if a printer is online?
Since the raspi sits in the same network as my printer, a simple ping checks the online status now - good enough for me as a workaround.
I am also looking for the documents for integrating Prusa Connect to our app
Hi there! Matt from Printago here. We'll be adding Prusa Connect support for Prusa printers to our cloud-based automation service! Come check us out or join our discord for updates! 🙂
I tried searching for an API doc for PrusaLink as I want to make this as local as possible - can anyone guide me in the right direction for the specification/documentation for PrusaLink API?
PrusaLink API specs are available at https://github.com/prusa3d/Prusa-Link-Web/tree/master/spec
PrusaConnect has publsished API specs for mobile https://connect-mobile-api.prusa3d.com/api/docs
Another one is a openapi spec for publishing camera images https://connect.prusa3d.com/docs/cameras/openapi/openapi.yaml
but as I am aware as of now there is no publicly available any other option.
