[Solved] Print queue
prc292
(@prc292)
Print queue
what use does the “Print Queue” serve. I can’t seem to start a print from it. Details say printer not prepared but overview says ready.
Best Answer by Timo:
You need to go to Command and then 'SET_PRINTER_PREPARED'
Click 'ADD COMMAND TO QUEUE' and it will start printing the first item from the print queue.
Napsal : 31/12/2021 1:57 am
1 lidem se líbí
Timo
 Timo
(@timo-2)
RE: Print queue
I have no special talent. I am only passionately curious
Napsal : 31/12/2021 7:51 am
1 lidem se líbí
prc292
(@prc292)
RE: Print queue
Thank you!
Napsal : 31/12/2021 11:21 am
natecox
(@natecox)
RE: Print queue
There should really be a shortcut on the print queue page itself for this. I'm not sure how a new user would intuitively know to do this.
Napsal : 22/01/2022 6:34 pm
Fred
 Fred
(@fred-7)
RE: Print queue
Je n'es pas la commande SET_PRINTER_PREPARED  sur la version 0.6.0?
Napsal : 25/01/2022 10:54 am
Fred
 Fred
(@fred-7)
RE: Print queue
De plus dans la Print Queue si je rajoute le meme fichier il metterait plus longtemps pour l'impression lorsque je regarde le barre graphe?
et si je rajoute un troisième fichier, celui-ci et bien dans la liste mais pas sur le barre graphe
Il faudrait apporter une correction
Napsal : 25/01/2022 10:59 am
Fred
 Fred
(@fred-7)
RE: Print queue
Le message SET_PRINTER_PREPARED dispo après avoir éteint puis rallumé l'imprimante bizzar...
Napsal : 25/01/2022 3:43 pm
Fred
 Fred
(@fred-7)
RE: Print queue
The printing does not start, even with the SET_PRINTER_PREPARED command!
example i have a print in progress i add another file in PRINT QUEUE then it never starts ...
Napsal : 01/02/2022 2:08 pm
Timo
 Timo
(@timo-2)
RE: Print queue
Posted by: @fred-7
That is not how it works. You will have to 'SET_PRINTER_PREPARED' after the printer is ready/finished with a job.
The printer state should be [READY] (green) after the 'SET_PRINTER_PREPARED' it will go to [PREPARED] (also green) and start the next job in the queue.
Napsal : 01/02/2022 3:33 pm
Fred
 Fred
(@fred-7)
RE: Print queue
I will try
If not, now everything is fine you saw my other post the problem comes from the SD card in the printer
Napsal : 01/02/2022 3:42 pm
Fred
 Fred
(@fred-7)
RE: Print queue
can we keep the bed at 100° and the nozzle at its temperature to save time between the two prints?
Napsal : 01/02/2022 3:43 pm
Timo
 Timo
(@timo-2)
RE: Print queue
Posted by: @fred-7
Do you swap the flexplate for a new one? Because most would let the bed cool to loosen the print.
Napsal : 01/02/2022 3:59 pm
Fred
 Fred
(@fred-7)
RE: Print queue
It doesn't work for me
Napsal : 01/02/2022 8:03 pm
Fred
 Fred
(@fred-7)
RE: Print queue
The PRINT QUEUE function only works if the next file is different, if it is identical to the first it does not work
Napsal : 02/02/2022 3:18 pm
Fred
 Fred
(@fred-7)
RE: Print queue
Is this normal, please take a look
Napsal : 16/02/2022 2:16 pm
Tojik
(@tojik)
Member Moderator
RE: Print queue
There should be a button above the print queue saying "Prepared" If there's none, it will be coming in the next version. I have tried printing the same file twice, and that alone works fine. Maybe there's an issue with metadata I didn't run into yet.
Napsal : 16/02/2022 2:48 pm
Netsim
(@netsim)
RE: Print queue
Printer ready function in menu on LCD could be useful.
When we finish all preparation ( cleaning plate, changing material) after selecting Printer Ready on menu it will start heating and printing next position from queue.
Napsal : 19/02/2022 9:07 am
Tojik
(@tojik)
Member Moderator
RE: Print queue
We know, but getting it into the firmware is very hard as at any time there's no extra space left on the einsy. They have to actively make space for features by optimizing the existing ones and that's hard. + there are other features planned. It's possible it will never get implemented and for sure it will not get implemented before 3.13
Napsal : 21/02/2022 4:28 pm
Fred
 Fred
(@fred-7)
RE: Print queue
I tried again, it doesn't work but with identical files, only with different files it works with the SET_PRINTER_PREPARED function
in the bar it remains hatched
Napsal : 02/03/2022 10:04 am
