Please allow raspberry pi with prusa link/connect to work with MK4
Sirrich
(@sirrich)
I was able to get a raspberry pi setup with prusa link/connect to work with my MK3 and it works great.   The usb webcam is available in prusa link and was able to attach it to prusa connect.   It seems to work very well!
I just got MK4 up and running.   Tried using the built in prusa link/connect and not able to setup a web cam and also it does not have the "CONTROL" tab
I tried connecting raspberry pi with prusa link/connect to the mk4 but it does not see the printer.
Can prusa enable connection to mk4 from the raspberry pi?
Also I am worried that if I get the mk3 to mk3.5 upgrade that I will not be able to connect the raspberry pi to that and will have no web cam or the "control" options.
Napsal : 05/02/2024 1:59 pm
Tojik
(@tojik)
Member Moderator
RE: Please allow raspberry pi with prusa link/connect to work with MK4
Unfortunately that is the case for now. The MK3 PrusaLink will not support the MK4, but we are working on a camera solution for it
It's mentioned in this article https://blog.prusa3d.com/prusa-connect-a-network-solution-for-remote-control-of-3d-printers_90364/
Napsal : 06/02/2024 12:10 pm
Sirrich
(@sirrich)
Thanks for the reply back Tojik.   I look forward to the continued enhancements to prusa link/connect.   The addon camera sounds good.
If you are able to get the raspberry pi prusa link working on the MK4 like it does on the MK3 that would be awesome.
Napsal : 06/02/2024 1:29 pm
