Octoprint on Windows Server
Qubiki 3D
(@qubiki-3d)
Hello there guy's I have a little question is there anychance to use prusa-link without raspberry pi ? I am owning home server with Windows Server 2019. Is there anychance to use it on this machine ? Or I must have Raspbery ?
Opublikowany : 07/05/2023 1:01 am
towlerg
(@towlerg)
RE: Octoprint on Windows Server
You can indeed run Octoprint on a window machine but the problem is that at irregular intervals windows apps will stall while the OS does some internal process, thus causing GCode streaming to stutter. If you want to try anyway, you'll find Windows binaries on the Octoprint site.
Opublikowany : 07/05/2023 11:21 am
Qubiki 3D
(@qubiki-3d)
atm I am runing Octoprint but I wanted to try Prusa Link 🙂
Opublikowany : 07/05/2023 12:33 pm
Tojik
(@tojik)
Member Moderator
Hi, PrusaLink does not support windows, you would have to run it under WSL or a virtual machine. Install instructions for linux are in the README file on Github. https://github.com/prusa3d/Prusa-Link
Opublikowany : 10/05/2023 10:21 am
towlerg
(@towlerg)
Ooops, I read Octoprint in the title and assumed thats what you wanted. Sorry.
Opublikowany : 10/05/2023 2:13 pm
