Multiple Issues With Farm
Supercadad
(@supercadad)
Mitglied
I must be honest I haven't had the best results whilst using prusa link/connect.  I am using the Pi Zero 2.
I have 8 printers, one of them in the process of being upgraded to try and successfully use the MMU2s.  All my printers have been modified to use Hemera system form E3D and one of them has the REVO on it (which so far is ace and has eliminated oozing between the heatbreak and nozzle)
I have noticed the following
Hardware setup is changing - With this i mean things like nozzle diameters and metal sheets are being altered without me doing so.  This messes up my Z calibration
One printer will now not accept SD cards, unless it is restarted
All printers will last about 24 hours before going into the error state.  This can be solved by rebooting the printer.  (Not just resetting it has to be a full power down.)
Veröffentlicht : 29/03/2022 9:32 am
Tojik
(@tojik)
Mitglied Moderator
Hello, sorry to hear that. I will have to ask what's your PrusaLink version - sound's like 0.6.0 judging by the error state bug.
Also, check you're on 3.10.1 on all printers if you are not absolutely sure
There is no intended way for us to change your printers nozzle diameters and sheet settings, so if that's happening it is a serious bug on our part
Was the SD card problem there before trying out prusa-link, does it go away if you unplug the raspi? (when the printer is off of course)
Veröffentlicht : 31/03/2022 1:29 pm
