Monathly/weekly updates how?
Yasar
(@yasar)
Hi ,is it possible to upgrade to a newer release?
i would appreciate it if we got monthly updates, or is there a source where you can already download "dev" images.... without compiling yourself?
I have install the latest image , but i have 5xx error and now and then offline messages.when its offline and go to prusa connect under settings i have no api key .... Is that the mistake/error?
firmware 3.12.0-BETA1-5536
PrusaLink 0.7.0.rc1
Uuid:
e83ebc43-f560-4a2a-9efd-f1c038b5e91c
Regards
Napsal : 19/11/2022 6:24 am
Tojik
(@tojik)
Member Moderator
RE: Monathly/weekly updates how?
Hi, the API key is a less secure way to authenticate compared to the HTTP Digest authentication we're trying to use. You can still set the API key in the config, but for the most part, please try to give the Digest thing a shot. You can change it in PrusaSlicer.
Sorry that we don't release. I would release whenever, but we don't have robust automatic testing, so each release is a lot of work for the testing department. You can install PrusaLink using the instructions on its github page in README. Section Dev Setup or something like that. It's not super complicated. If you get stuck, feel free to ask. If you want a better way to chat about any issue, try our Discord server. Links to invites are under every PrusaLive on YouTube
This month and the previous month we worked on cameras, it's still kinda buggy and missing some settings but it should (Jo wants it to) come out soon
Napsal : 21/11/2022 10:58 am
Yasar
(@yasar)
  • @Tojik
Thank you i will try it to.compile on next weekend 🙂
No i mean that prusa connect doesnt work properly , it mean http error 5xx and the i have no.connection to cloud and pi .... I send the gcode to the cloud via prusaslicer api to connect.prusa3d.com....after that i power on my mk3 and print 🙂 .... But i use it daily ... I miss camera and an mobile app or home assistant plugin (i have found an prusa connect plugin but it use api v2...)  But thank you i working good 🙂
Napsal : 21/11/2022 4:43 pm
Tojik
(@tojik)
Member Moderator
We are stuck on cameras. Everyone is working on that. I don't believe the occasional 5xx is is fixed anywhere. I have an RF shield in the works but I was encouraged to do it as my personal project, so it sits in a pile of those :/ It improved the WIFi reception significantly, but I have a problem with grounding. Would love to finish that.
I do not know about the other stuff, sorry.
Napsal : 21/11/2022 4:48 pm
TMS
 TMS
(@tms)
As much as I can understand that, I just wish that PrusaLink was built with a modular/plugin approach so that camera plugin development/debugging wouldn't slow down the release of the main PrusaLink package.
I know you work hard, and I truly appreciate every effort put in; it just feels that delivery is slow because pieces of code and features are too "hardwired" to the main core.
Posted by: @tojik
Napsal : 21/11/2022 5:10 pm
Tojik
(@tojik)
Member Moderator
I haven't made anything modular (as in community modded it to hell and back) yet, honestly I feel like that's the exception. I imagine one can mod PrusaLink juust fine, it's just that there's not that much interest in doing that. I don't have a module repository and an easy way to turn them on and off, why lose time doing that when there's no modules. But Python as is, is pretty permissive to modifications, so it's possible. So far, there hasn't been a single PullRequest from outside, so there seems to be very weak interest so far.
Napsal : 22/11/2022 12:33 pm
Yasar
(@yasar)
Posted by: @tojik
I would like to tell you something, I always lost the connection to prusa connect, it always showed http error 5xx ... well ... I reinstalled the image and installed everything and when installing I have NO hook at API set ... and have not seen a http 5xx error for 24 hours and the connection is and remains stable. A tip for those who have http errors 🙂
Napsal : 25/11/2022 8:45 pm
Tojik
(@tojik)
Member Moderator
The occasional http error that immediately resolves itself seems to be on the connect side. So as our DevOps magician Martin does hos thing, the frequency should decrease. The RC2 should have these silenced
Napsal : 25/11/2022 9:00 pm
1 lidem se líbí
Yasar
(@yasar)
good morning 🙂
I don't mean http resolved error, i mean http 5xx error ,where I then  no connection to the cloud connect .... not that you misunderstand it 😀
Napsal : 26/11/2022 8:25 am
Tojik
(@tojik)
Member Moderator
Sorry for misunderstanding. I cannot quite decode what exact problem could have caused this, but am glad that a re-install solved it
Napsal : 27/11/2022 10:11 am
Yasar
(@yasar)
@Tojik
nice rc.2 is online can you make an image ... i have problems on compiling .... thank you for the camera feature 🙂
Napsal : 01/12/2022 4:38 pm
Tojik
(@tojik)
Member Moderator
oh right. I just pushed the rc2 tag, i realized I don't have the release notes. It was supposed to be done today, and it wasn't so i tried and got stuck :/
Napsal : 01/12/2022 5:08 pm
1 lidem se líbí
SPŠT
(@spst)
Hello,
when I want to connect the camera to the printer using an external webcam that would be connected via USB to the pi 3B, is it possible now? and how? Thank you
Napsal : 15/12/2022 6:32 am
Tojik
(@tojik)
Member Moderator
Hi, this feature is part of 0.7.0 RC2 which is being tested. The image is not out yet. The only option to get it is from the github repository Prusa-Link. Sorry it's taking so long. Thank you
Napsal : 15/12/2022 8:56 am
