MMU3 Filament active
NavyPixel
(@navypixel)
I have recently installed and running my new MMU3 on my mk4 printer, i wanted to know if its possible to pass which filament is loaded in the MMU3 over to home assistant somehow?
i want a strip of LED behind the 5x Rolls and only show the LED when a certain roll is active, when it switches to color 2 i also wanted the LED to activly follow it in a pattern.
i know prusaLink shows which MMU roll is active but connect does not.
any ideas?
Napsal : 05/09/2024 8:17 pm
_KaszpiR_
(@_kaszpir_)
RE: MMU3 Filament active
Looking at the https://github.com/home-assistant/core/issues?q=sort%3Aupdated-desc+label%3A%22integration%3A+prusalink%22+is%3Aclosed MMU support is since 19th June so I assume you use updated version?
Then there should be some additional (binary?) sensors available for mmu.
Sorry but cannot help more because I don't own MMU.
Napsal : 06/09/2024 7:46 am
NavyPixel
(@navypixel)
thanks i just checked and i have the MMU sensor but this just shows if MMU is ON/OFF;
Napsal : 06/09/2024 9:42 pm
_KaszpiR_
(@_kaszpir_)
What is the output if you query the printer API?
There may be some additional data there, but maybe it is not processed by the HomeAssistant plugin...
Napsal : 07/09/2024 9:26 am
LarGriff
(@largriff)
This seems like a good use for the GPIO board.
Posted by: @navypixel
any ideas?
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Napsal : 11/01/2025 3:12 am
