MK4 settings
Pking
(@pking)
MK4 settings
In the PrusaConnect settings under LAN settings it says
"To connect a 3D printer using PrusaLink, you need to download the prusa_printer_settings.ini configuration file and load it."
So I have downloaded the .ini file but how do I load it and to what?
Under API keys it says
"You can use the API key to connect the internal API of PrusaLink to other applications. For example, PrusaSlicer can upload files to PrusaLink after slicing."
But How do you do this?
Best Answer by Tojik:
Hi, there are two ways to connect the MK4 to Connect, one is as you described, setting up the printer in Connect, then downloading the file onto a flash drive. Then going into your printers settings -> network > connect and selecting Load settings.
The other way would be to go into the same menu and selecting Add printer to Connect and scanning the qr code with your phone.
This guide https://help.prusa3d.com/article/sending-g-codes-to-printer-via-network-prusaconnect-prusalink-octoprint_196761#:~:text=PrusaSlicer%20separates%20the%20printer%20connection,and%20picking%20Add%20physical%20printer. tells you how to use the API key.
Hope this clears it up
Respondido : 07/04/2023 5:33 pm
Tojik
(@tojik)
Miembro Moderator
RE: MK4 settings
Respondido : 07/04/2023 7:06 pm
