Inject start/end gcode
Hi!
we're sharing a MK3 with PrusaLink/Connect in our office.
I'd like to be able to change filament after each print and heard about adding custom gcode to retract filament after a print completed. This would need to also have a longer purge line in the start of a print.
Is there a way to add this custom code when it reaches the printer?
Thank you
Napsal : 07/05/2023 7:56 am
RE: Inject start/end gcode
If you use autoload you should only need gcode to remove the filament at the end of a print
Regards Joan
Napsal : 07/05/2023 11:38 am
