Ideas of Future Updates
Timothy LeGower
(@timothy-legower)
Hello,
I've been using Prusa Connect and Link for just a little while and I had a couple thoughts for future capacity.
1) the ability to run calibrations from Prusa Connect.  PID, Mesh leveling, etc.
2) the ability to see and adjust fan speeds through Prusa Connect. Injust had an issue where my printer was starting thermal runaway and I ran down to the basement to see and the fans had kicked on too high, so it would have been great if I could have seen that and corrected it direcy from Prusa Connect.
3) this is more a firmware change, but for Prusa connect.  Sometimes I'm down at my printer and want to start up a print while I'm there, but I haven't found a way to see the files stored on Prusa Connect from the printer itself, just what's on the SD card. So it works be nice to be able to see and run prints directly from the printer itself. OR the ability to upload files in Prusa Connect and save them to the SD card.
Thanks!
Tim
Postato : 13/01/2024 8:22 pm
Tojik
(@tojik)
Utenti Moderator
RE: Ideas of Future Updates
Hi, MBL can be run from the visualisation widget. Fan speeds should be visible alongside temperatures on the graph, but adjustments seem to be missing.
The ability to see Connect files from the printer or uploading to the SD are unfortunately not going to happen, but you can set the printer to Ready from the LCD menu. On 0.7.2 add a folder to the SD card named "PrusaLink menu", a file named SETREADY.G should appear.
0.8.0 will have that done in a more user friendly way.
Hope this helps at least a little bit 🙂
Postato : 15/01/2024 11:12 am
Timothy LeGower
(@timothy-legower)
Thank you very much!
I check those things out!
Postato : 15/01/2024 12:38 pm
