[Idea] Show pending printer pairing indication on PrusaLink/PrusaConnect
showtek
(@showtek)
I noticed that while registering a printer via PrusaLink and getting redirected to Prusa Connect, if you are not logged in, you get redirected to a guest page, however when you do log on and get redirected to the dashboard, you are no longer able to finalize steps with pairing on either platforms ( PrusaLink/PrusaConnect ) as there is no button or information about the process, only generic step info at "Add New Printer" page.
The only way I was able to successfully pair the Printer together is to visit the redirect link from Chrome history, that contained the URL slugs with identifying printer UUID  & some other params and finalize there.
Therefore I think a good suggestion would be to have some form of pending indicator/button or a function that tracks if linking was successful either on PrusaLink or PrusaConnect to avoid this trouble.
Opublikowany : 20/02/2022 11:32 pm
Tojik
(@tojik)
Member Moderator
RE: [Idea] Show pending printer pairing indication on PrusaLink/PrusaConnect
Hi, they intend to fix this with an add printer again button in the PrusaLink local web interface. Hope that will be enough
Opublikowany : 21/02/2022 4:40 pm
1 ludzie polubili
sblomfield
(@sblomfield)
I also ran into this. Thanks for the update Tojik.
In my case since I didn't have the redirect in my chrome history, I renamed /home/pi/prusa_printer_settings.ini and restarted prusa link. It went through the registration process again and this time since I was logged in, it was successful.
May I also suggest that the login page retain the original URL and redirect there after login please? This was what I expected to happen, and in that case it would be a non-issue.
Opublikowany : 25/02/2022 2:17 am
Tojik
(@tojik)
Member Moderator
Hi, nice to see you here. This is fixed in the dev version, so it's coming in the next update
Opublikowany : 25/02/2022 6:15 pm
