How does Prusa Connect Queue work?
Phil
 Phil
(@phil-15)
I can't get the queue to work in Prusa Connect. I am sure it is an operator error.
I queued a couple of print jobs. Why does each job say "The file is not uploaded to the printer"? And even though I clicked the "Set Ready" button the printer never advances to the next print job?  Take a look at the screenshot I attached. Thanks.
Prusa Core One
Napsal : 11/01/2026 5:05 pm
JP Guitars
(@jp-guitars)
RE: How does Prusa Connect Queue work?
Is it possible you already have files of the same name on the printer? If there is then it cannot upload the file.
Napsal : 11/01/2026 5:08 pm
So what do you see on the Printer Files tab? Are the files there? You can get this message when you upload a file, queue it, then delete it from the printer (before printing).
Napsal : 11/01/2026 6:34 pm
JP Guitars
(@jp-guitars)
@phil-16 did either of these suggestions help?
Napsal : 14/01/2026 5:17 pm
RobertLikesToPrint
(@robertlikestoprint)
I have the same issue.
It worked fine until now, and I didn't had any issues with duplicate file names.
Now the files in the queue are not uploaded anymore on the printer, even though with print immediately it works well.
Also when the file names are unique it still does not work.. maybe they changed some settings on their cloud server, but they should change them back!
Napsal : 22/01/2026 6:18 am
Fuzzybits
(@fuzzybits)
I'm running into the same problem. I rarely use the queue, but since the problem with Prusa Connect yesterday where everyone's printers appeared offline incorrectly, I added my file to the queue. It's there, but showing "The file is not uploaded to the printer".
Now that my printer is online, I should be able to get the file uploaded and printed, from within the queue. But there seems to be no way to do that. If I go to the "Connect File" tab, I can see the file there and trigger a print. But I should be able to do that from the queue, particularly if I've set the printer to ready state.
Napsal : 03/03/2026 5:27 pm
cmpickle
(@cmpickle)
This might be related to an issue that I ran into. I found out that if you remove the USB drive from the printer you won't be able to upload files via prusa connect. So make sure the USB drive is still inserted and it is not full.
Napsal : 25/04/2026 12:35 pm
