Has anyone successfully setup PrusaConnect with Pushover notification via a webhook?
Cranky Curmudgeon
(@cranky-curmudgeon)
I've been trying to do this all afternoon with no luck.
I know it's possible to do it with Curl and Python but the Slack labeled Webhook is our only choice for PrusaConnect.
Definitionally need better notification options with PrusaConnect and this would make it perfect.
Publié : 04/10/2024 9:26 pm
_KaszpiR_
(@_kaszpir_)
RE: Has anyone successfully setup PrusaConnect with Pushover notification via a webhook?
Pushover does not support webhooks as Discord or Slack does it.
You would need a middleware for that to translate one incoming message from PrusaConnect  to a message pushed to PushOver.
For single user it may be easy to set up yourself, but for a massive amount of notifications it requires paid service agreement with PushOver to register new app.
Publié : 05/10/2024 7:58 am
Cranky Curmudgeon
Thanks for confirming this.
I ended up using IFTTT as a bridge between PrusaConnect and my Hubitat home automation system.
The Webhook feature of IFTTT works great with PrusaConnect's Slack notification feature. From there, I can do most anything within Hubitat (SMS, Pushover, spoken messages, etc...).
Publié : 05/10/2024 3:23 pm
Larswa
(@larswa)
Good idea with the middleware. I use Pushover for a ton of things and wanted them in there too.
Too bad there is not a more clean generic webhook where we can map what we want to send out, so I had to go with the Discord webhook.
I wrote a short Python function that receives a discord post messages and tries to fish out relevant content and send it on to Pushover
lmk if you want to see the code. I got blocked by some wordpress plugin when I post it here.
Publié : 16/01/2025 2:46 pm
_KaszpiR_
(@_kaszpir_)
Try GitHub gist.
Publié : 16/01/2025 3:42 pm
Larswa
(@larswa)
Oh yeah ... good thinking
https://gist.github.com/Larswa/aed175d8eb3f9809df538efab5931ee1
Publié : 16/01/2025 4:02 pm
1 personnes ont aimé
_KaszpiR_
(@_kaszpir_)
so I guess the setup is like this:
- you host it somewhere like heroku app, that gives you a public endpoint
- in PrusaConnect set Discord as target for notifications but with custom url pointing to that public endpoint
- endpoint gets notifications as Discord format,  and processes them and thus sends them PushOver.
Publié : 17/01/2025 1:35 pm
Larswa
(@larswa)
Exactly. In my case I chose the free tier Google Cloud Functions as its dead easy to set up. A lot less steps than AWS lambda for instance (IMO).
You are probably at home in there, but for others its something like this
Go here to enable google functions  https://console.cloud.google.com/functions
After clicking around to enable Google Functions on the account, create one and set it as a HTTP triggered function.  Select "Allow unauthenticated invocations" and go with default memory allocation.
Select Python 3.12 as the execution engine, and there is a main.py and a requirements.txt textbox where you paste in the code.
Then its possible to test the function, or just deploy it and test it with the endpoint that is created.
Rough sketch of what to do, but Google have probably changed the UI of creation 3 times while I write this up. 😂
I really should go ahead and put it in a container so we can run it somewhere locally off the net, but I just couldnt be bothered as I only had half an hour to get it up and running.  ChatGPT gave a rough draft of the Python code, and I made only a few corrections to it.
Publié : 17/01/2025 1:45 pm
Michael
(@michael-33)
Thanks for that proposal, I managed to solve this for me with a raspberry pi running the code shared above with docker and using pushover like this.
Since the raspberry was there anyways, it was a matter of minutes, and I hated getting the 'native' notifications from the prusa app delayed so often.
Thanks for sharing!
Publié : 10/11/2025 2:34 pm
Michael
(@michael-33)
maeh, sry - forgot to test it properly, it was just working from within my network / command line curl, of course not from outside. not there yet 😉
Publié : 10/11/2025 2:48 pm
Larswa
(@larswa)
😂🫣 So relatable. It's working ... It's actually working! Oh noooo... It's not working..and then. Did this ever actually work? 😂
I'm sure you'll get it there and I look forward to seeing the raspberry pi solution for this.
Publié : 10/11/2025 4:25 pm
Larswa
(@larswa)
Larswa
(@larswa)
Michael
(@michael-33)
Posted by: @larswa
I am so sorry, I was too busy doing all the docker stuff and port mapping, and in the very end I figured out that Prusa Connect is calling the webhook from the cloud, not from the printer. But yes, I will find a way to get that solved and follow up here. It's a shame there is no simple webhook to be called from the printer - this would make things much, much more easy and versatile.
(I tried to remove my post after I failed so miserably above, but the forum did not allow it to be removed anymore ...)
Publié : 10/11/2025 4:53 pm
_KaszpiR_
(@_kaszpir_)
You need a globally available IPv4 endpoint to allow PrusaConnect to talk to it - something like a publicly available AWS Lambda or GCP Function or your home server publicly available or similar.
Publié : 10/11/2025 11:11 pm
