Feature Request - Infobox for personal Information to currently loaded filaments/installed steel sheet, etc
JanniGogo
(@jannigogo)
Membre
We are using two Prusa XL in our Design team and often start prints from home so we cannot see what color of filament is laoded or what stell sheet is installed.
Maybe some kind of info box could be added to every printer in prusa connect to add information manually, that is not tracked be the printer or the slicer but might be of interest for planning print jobs without being near the printers.
Publié : 08/04/2025 12:50 pm
1 personnes ont aimé
RE: Feature Request - Infobox for personal Information to currently loaded filaments/installed steel sheet, etc
Would Webcams help?
Publié : 08/04/2025 12:55 pm
JanniGogo
(@jannigogo)
Membre
We will install webcams for sure, but sometimes filament with similar but jet different colors might not be distinguishable on cam. Same might be the case with satin sheet vs. textured sheet.
Publié : 08/04/2025 2:09 pm
Are you printing from a drybox?
If not this habit is a mistake.  Leaving a printer loaded but not printing is a recipe for stringing and other humidity problems.  For good quality prints you need to load the printer and start printing immediately so there is a better chance of using up the outer layers of filament before they absorb too much moisture and reduce the output quality.
Publié : 08/04/2025 4:13 pm
TeachThePrints
(@teachtheprints)
You can abuse the Settings Location for that. It'll then neatly show the info on the main page of the printer like here:
Posted by: @jannigogo
Prusa Mini FW6.2.4
Publié : 21/04/2025 9:48 am
JanniGogo
(@jannigogo)
Membre
@teachtheprints, that's a good workaround! Thanks for the input. Even though I added the actual location that's a better way to use the location settings as all our printers are located in the same room.
Publié : 21/04/2025 2:20 pm
