[Feature request] Expose Printer's IP address on Prusa Connect
After a while, my MK3 using eduroam wifi network obtained a different IP address. That is not a problem but I have failed to see any way on the Prusa Connect website to learn about your printer IP address.
Of course, if your printer is close to you it is easy to just look at the LCD display, but I think for some use cases it might be useful to expose the printer's IP address on Prusa Connect site.
Best Answer by DanielAttia:
You should be able to see "Network Info" such as WIFI IP Address under the settings tab in Prusa Connect.
Opublikowany : 10/11/2021 3:58 pm
RE: [Feature request] Expose Printer's IP address on Prusa Connect
Opublikowany : 10/11/2021 5:04 pm
Topic starter
answered:
Thanks a lot @DanielAttia. You're absolutely right.
Requested feature was already there 🙂
Opublikowany : 10/11/2021 5:47 pm
1 ludzie polubili
