[Feature Request] Allow custom endpoint URLs for notifications
DonFilipe
(@donfilipe)
I'm trying to develop a tool with the PrusaLink API and am currently stuck at getting the notifications. Since the only available options are Slack, Telegram, Discord and Browser, my idea was to setup some PHP script which mimics a Discord webhook endpoint and takes the content according to the Discord webhook api specification. Unfortunately, when I try to do so Prusa Connect tells me that my endpoint url is invalid.
Is there any chance to provide a custom endpoint url to receive notification data in the future?
Best Answer by _KaszpiR_:
You can have custom url in any in those, I use my private web server as an endpoint for slack. Afair there is no url check, unless they recently added it.
The only thing it does is just different parameters passed to the endpoint, based on the selected formatting so that sent message as json has different object structure, those are really small differences between slack and discord.
I strongly recommend using echo-server as an example what comes in.
Respondido : 15/02/2024 4:09 pm
_KaszpiR_
(@_kaszpir_)
Respondido : 15/02/2024 5:54 pm
DonFilipe
(@donfilipe)
RE: [Feature Request] Allow custom endpoint URLs for notifications
Thank you, I will definitely try the echo-server thing out. Do you also see a "!" icon next to your endpoint url in the notification settings? Maybe they just do validation for a warning but still send data and that means I'm doing anything wrong. But maybe the echo-server will help
Respondido : 15/02/2024 6:36 pm
DonFilipe
(@donfilipe)
Okay I just found it out by testing with an echo server what I did wrong, thanks for this amazing tip 🙂 Anyways, there is a URL validation when configuration Discord endpoint URLs but it still sends the data even though the URL might be invalid. When using the Slack tab there is no such validation.
Esta publicación ha sido modificada el hace 2 years por DonFilipe
Respondido : 15/02/2024 7:03 pm
DonFilipe
(@donfilipe)
Okay sorry for the spam but I can't edit my posts for some reason.
It seems that the URL validation is the same everywhere. I was tricked because the echo server worked, but when I tried to add my own server again it doesn't work, no matter which tab (Slack, Discord, ...) I choose. I will keep trying but it would be really helpful to understand what the endpoint url is actually validated against
Respondido : 15/02/2024 7:19 pm
Unfortunately due to heavy spamming, Prusa decided to restrict editing rights to a very short time window. which leads to the issue you have noted
Respondido : 15/02/2024 10:20 pm
1 les gusta
_KaszpiR_
(@_kaszpir_)
@DonFilipe and what do you enter as url that it does not work?
Respondido : 15/02/2024 10:51 pm
DonFilipe
(@donfilipe)
Sorry for the late reply. Now I finally found out what's going on - I think 😅 I chose the wrong path on my web server and it seems that Prusa Connect is just checking if the given endpoint exists (maybe some status code check). After I fixed it, the checkmark icon appears next to the endpoint url. When I delete the files from my webserver again, the "!" again can be seen. So it was all on my side, sorry for this. But in the end it's working, so thanks a lot! 🙂
Respondido : 17/02/2024 1:39 pm
2 les gusta
