Disable beep on error
Mark Hähnel
(@mark-hahnel)
Hi everyone,
is there currently a way to disable the beeping when some error or issue happens when using PrusaLink?
Sometimes my wifi drops and it's beeping because the "error is resolved". And with a long print this gets kinda annoying when it beeps loud at you multiple times a day.
Best regards,
Mark
Napsal : 22/12/2022 3:35 pm
Tojik
(@tojik)
Member Moderator
RE: Disable beep on error
Hi, it isn't your wifi, it's our dropped connection. We still don't quite know what is causing it, but recently we managed to reduce that somewhat. Also, there's a temporary fix in 0.7.0rc2 you can get it over here - https://github.com/prusa3d/Prusa-Link/releases/tag/0.7.0rc2
It's a new image. I know we need a more user friendly way to back up your prusa_printer_settings.ini file. Right now I think it's best to just go through the wizard again. Or you could try downloading it from Connect and restoring it in the first step of the wizard.
Napsal : 22/12/2022 5:14 pm
Mark Hähnel
(@mark-hahnel)
Hi, thanks, now i know it‘s not my wifi. But i have the problem on the RC2 which i flashed today. It happens about once every 30-60minutes.
Can i send you some logs which would help you to narrow it down?
Mark
Napsal : 22/12/2022 5:17 pm
Tojik
(@tojik)
Member Moderator
Send away, I'm not at work tho, so if it beeps too much, the only other fix is to silence the printer, or yeet PrusaLink. Sorry. Will look at logs
Napsal : 22/12/2022 5:31 pm
Mark Hähnel
(@mark-hahnel)
The logs are attached.
Have a nice evening!
Napsal : 22/12/2022 5:38 pm
