Connect Files
Hello,
today I updated prusa connect 5.5.0, not bad especially "connect files" now it's a shame you can't put a quantity for the addition to the print queue.
RE: Connect Files
I just saw that new tab too. Interestingly, I have one file that always shows as a result, regardless of what filter option I set. It's sliced for the Mk3S with a 0.4 mm nozzle, but shows up when I ask to show me XL files only, 0.6mm files only, etc etc ☹️
Anyway, would be very nice to be able to say "queue five copies". Right now you have to go into the queue and duplicate the job several times.
What's also missing (and has been since day 1) is an option to upload a file from the printer (USB drive on XL, Prusalink or SD card on Mk3) to PrusaConnect. My workflow is usually to send jobs from Prusaslicer to the printer for a test print, and then I would love to say "copy to PrusaConnect" without first having to export a GCODE file.
BTW, how do you know it's version 5.5? I don't see any version numbers in the PrusaConnect UI?
RE: Connect Files
Thank you!
Jesus Christ, hovering over an almost invisible text on the bottom of the screen… who came up with that? Talk about undiscoverable… instead of putting it under the big Help menu…
RE: Connect Files
Couldn't you make it so that when you press the duplicate button, you set a quantity? With a default of 1 for those who only want to duplicate?
