Connect Files and Print Queue
Fred
 Fred
(@fred-7)
Hello,
It's a shame that it's still not possible to specify a quantity to print? rather than having to press 10x to print 10x a file.
Opublikowany : 06/09/2023 8:19 am
1 ludzie polubili
Foster Bronson
(@foster-bronson)
RE: Connect Files and Print Queue
Hello everyone!))
Opublikowany : 22/05/2024 12:53 pm
FabrikMEF
(@fabrikmef)
Hello, indeed the possibility of specifying the number of occurrences of the print to send to our printers would be a very welcome addition.But with another modification coupled with this: when a file is sent to the queue it is also loaded on the MK4 and therefore it appears on the screen. If you start printing from the printer, the file will not be included in the queue. For example, it would be necessary to consider deleting an occurrence from the queue if the file is completed based on its file name, for example prusa connect can I think have this verification.
Opublikowany : 22/05/2024 2:33 pm
2 ludzie polubili
Grant
(@grant-6)
Hey everyone!
I agree with both ideas, adding multiples and the queue recognising when the next file has been manually started, though this could cause problems if you have multiples of a file in the queue and you’re manually restarting a print after a failure.
I'd also love to see the attribute of material weight added to the queue information as it would help for planning.
Also the ability to set a desired start time to a file midway through the queue would be helpful when you’re planning multiple days of printing and only have access to the printer during work hours.
Opublikowany : 23/05/2024 3:39 am
