Confusion if printer is off when enqueueing prints...
Mk4User
(@mk4user)
I often enqueue prints for my Core One while it is switched off. Then I walk from the PC to the printer to turn it on and print.
My expectation would be that when the printer is turned on, it checks PrusaConnect to see if there are new prints enqueued. But it seems that the printer does not do that.
Eventually I will go to the PrusaConnect website on my smartphone and try to start the print from there, from the print queue. The GUI then suggests that it has started the print, but nothing happens on the printer. I can repeat this many times and nothing changes.
Eventually, when I move over to the printer page on PrusaConnect, it shows the print and an error "was not transferred to the printer" (or similar). *That* message comes with a little side menu which has a "Retry" item. When I hit that Retry, it finally works - the print will be uploaded to the printer, the printer shows it on the LCD, and will start printing.
All of this is 100% reproducible, every time. It has been this way for a long time, also on the MK4S which I had before the Core One (it was an upgrade, so the same Buddy board). It happened through several firmware updates.
Since it has happened so long (months) I cannot imagine that this is a bug - I would hardly be the first or only one, and someone surely would have fixed it. So my question is, what am I doing wrong? Is there a correct way to have the printer detect prints? Can I do something on the printer itself so it actively checks the queue and picks up the next item, and don't have to play around on the smartphone? This is my only printer, so the prints are all enqueued for this printer anyways.
Publié : 15/10/2025 11:52 am
