Compatible Wi-Fi cameras
gkPrints
(@gkprints)
Hi
I'm thinking about getting a camera that I want to add in PrusaConnect. Is any Wi-Fi camera compatible with it? What do I need to look for?
I'm interested in a small low cost cam since I don't need it very often.
Thanks in advance!
Napsal : 31/01/2025 12:33 pm
JP Guitars
(@jp-guitars)
RE: Compatible Wi-Fi cameras
Lowest cost is going to be an Arduino ESP32-CAM, will cost under £10/€10/$10
https://www.printables.com/model/668369-esp32-cam-case-and-mount-for-mk4
Or any of the remixes
Napsal : 31/01/2025 12:41 pm
1 lidem se líbí
gkPrints
(@gkprints)
I only briefly looked it up before and I thought I would need quite some parts that cost around 30-40 Euros in total. But if I only need to get the ESP32-CAM-MB module that's a nice little camera. Thanks!
But anyways: Is any WiFi camera compatible?
Napsal : 02/02/2025 8:45 pm
JP Guitars
(@jp-guitars)
Don't think so. Something needs to push the photos up to server so you need something that is capable of doing that. The Esp cam being based on an Arduino is programmable so you can get it to do the necessary. The software that Prusa have written for the esp does the donkey work for you simply.
Napsal : 02/02/2025 8:50 pm
_KaszpiR_
(@_kaszpir_)
Not every wifi camera is suitable, the best ones are esp32 with custom firmware ( thus all in one standalone solution).
Other option is to use camera which exposes stream or still images available over local network, but then you would need extra code running somewhere else ( raspberry pi or PC/nas) and then you could use something like a https://nvtkaszpir.github.io/prusa-connect-camera-script/ via curl or mediamtx with ffmpeg
Napsal : 03/02/2025 9:05 am
Tried the ESP32 cameras, wasn't impressed. I prefer my stand-alone Wyze cams that IMO have better picture quality and more features such as continuous recording to SD card. No, they're not integrated into Connect but the Wyze app is excellent.
Napsal : 24/02/2025 6:33 pm
_KaszpiR_
(@_kaszpir_)
FozRun3D which model do you have?
Napsal : 25/02/2025 12:49 am
I have  mostly Wyze cam v3 https://a.co/d/31Vtaly and some older v2 (I'm not sure they're still for purchase)
Napsal : 25/02/2025 3:16 am
1 lidem se líbí
