Clear Bed From Printer
wamfox
(@wamfox)
Not sure if this is technically possible but the ability to set the print bed as clear (“set printer ready”) from the printer itself instead of using the web interface would be amazing from an efficiency and ease of use standpoint. Wether it could be done through the printer interface or with a button connected directly to the pi, being able to add items to the print cue then remotely start the next print from in front of the printer once you have cleared the bed would be awesome.
Opublikowany : 14/07/2022 9:09 am
1 ludzie polubili
Tojik
(@tojik)
Member Moderator
RE: Clear Bed From Printer
Hi, getting a button into the main menu proved inobtainable right now, the fw team is squashing a far more important issue. The 0.7.0 will have a hidden feature activated by putting a folder named "PrusaLink menu" onto the root of the printer SD card. A file named SETREADY.G will get created automatically, "printing" it should do what you're asking for 😅
Opublikowany : 14/07/2022 9:30 am
1 ludzie polubili
wamfox
(@wamfox)
Awesome! I look forward to the update.
Opublikowany : 14/07/2022 11:28 am
1 ludzie polubili
