Bed level visualizer
Laky
 Laky
(@laky)
Mitglied
I would like to test Prusalink, but before I install it, I want to ask.
So far I use octoprint with plugin bed visualizer.
Is there such a possibility in Prusalink?
I use it for bed comparisons.
Veröffentlicht : 23/12/2021 3:58 pm
Eric E
(@eric-e)
Mitglied
RE: Bed level visualizer
Hmm.
I use the bed level thingie once.  It looked good, and never used it again.
Are you using it to look-see at each build plate?  Or bed comparison between printers?
Don’t trust forum advice.
Veröffentlicht : 24/12/2021 9:51 pm
Laky
 Laky
(@laky)
Mitglied
I use it on new steel sheet and as a check that the Z axis is parallel to the bed. Over time, stepper motors always turn a little against each other.I wrote the beginning of the G-code so that every time I print, the values are displayed in the plugin so that I can see that the X-axis is parallel and the pad is straight.
Veröffentlicht : 26/12/2021 11:26 am
Snowdonia 3D Printing
(@snowdonia-3d-printing)
Mitglied
I'd like to see a visualizer as well, or at least the data points in a grid - it's a handy tool to be able to check the mesh data if things start going wrong
Veröffentlicht : 06/01/2022 2:33 pm
JayMac
(@jaymac)
Mitglied
A bed visualiser would be a much appreciated addition, it's the only single reason I still keep my old Pi4 floating about.
Thanks
Veröffentlicht : 30/01/2022 12:27 pm
SirPoonga
(@sirpoonga)
I have started using Connect and I like it.  The bed level visualizer plugin in Octoprint is why I still have the Octoprint microsd card next to the printer.  Also for cotolapse stuff.
Veröffentlicht : 15/06/2022 5:10 am
Tojik
(@tojik)
Mitglied Moderator
Good news, support for bed visualization should be coming next release, whenever that is. 0.7.0 should be sending the necessary data.
Veröffentlicht : 15/06/2022 1:03 pm
JayMac
(@jaymac)
Mitglied
Great news @Tojik 😀
Veröffentlicht : 15/06/2022 1:30 pm
