Activate and deactivate Silent Mode from PrusaConnect
If would be nice to be able to control the Silent mode when the LCD is not in front of you. Imagine the following scenario: silent mode was ON during the night, the following morning you leave home without turing it OFF and thus, the printer is losing productivity. If it could be turned OFF from Connect it would make it work at full pace again.
RE: Activate and deactivate Silent Mode from PrusaConnect
Was googling this for this exact scenario. Should be a simple feature to add I guess
- typically about 3% faster
If you are doing this cycle remotely you will see perhaps twenty minutes difference over a 24 hour print. If your margins are this tight you have bigger issues to fix.
It depends on the very print job itself. If there's a lot of travel moves I've seen up 4 hours of difference / 24 hours. But other than manufacturing throughput it's about convenience and gaining the LCD features as a remote controller.
On my mk4s, where it has printed for 2h45m, it jumps from being done on 4 hours to 3h25m by turning of silent mode. It's definitely a nice operation to adjust remotely.
Cheerio...
I see the same behavior on the XL, disabling Silent Mode significantly reduces print time between 10 and 25 percent depending on the print. I often leave Silent Mode enabled for noise reasons, but when the printer is running unattended, the ability to toggle it remotely is something I would use all the time.
This is already supported in Bambu, please add this to Prusa Connect.
Yet another vote for this feature, in my case it would be useful to save me a trip of getting up from bed when I'm trying to sleep, but then realize I'm still hearing the printer from a couple rooms away. (It turns out that my dog was sleeping in a chair right next to the printer, so I'm sure he'd appreciate it too)
