y-axis vibration in 1 direction
ilyad
(@ilyad)
Hi
I Assembled my Mini Kit and everything went great. i have onlyy one isseu and that is that the bed is having a lot of vibration when the y-axis is moving towards the back during prints. It results in wobbly lines.
What can i try to fix this. I playd a lot with belt tension and that did not solve it.
Publié : 05/07/2021 7:45 am
mrstoned
(@mrstoned)
RE: y-axis vibration in 1 direction
I would try to loosen the screws on the front and back plate, move the bed all the way back, slightly tight the screws on back plate, move the bed fully forward, slightly tighten the front screws and check for a smooth bed movement and then re-tighten all screws.
Also the same for the the bearingholders. If one is just ever so slightly out of alignment it could cause the same issue. Binding during travel.
Prusa Mini+ kit. BondTech extruder. FW 5.1.2
Prusa MK3S+ kit. Stock. FW 3.11.0
Prusa MK3S+, used. Stock. FW 3.13.3
Publié : 06/07/2021 5:43 pm
