What is the fuse inside the kettle plug itself?
I've recently moved and I packed my printer away, now for some reason I didn't put the kettle lead that plugs into the power brick with everything else! I've found one and I believe is the original but i'm wondering if there is any way to tell?
If not I dont think it would matter my only main question is what size of fuze does the mini have, i've found a plug with a 10amp fuse that i'm 99% sure is the original but i'd really just like to confirm if that's the right size fuse or not.
This is the plug I have found!
Many thanks,
Liam
RE: What is the fuse inside the kettle plug itself?
I ended up contacting support so replying here incase anyone ever needs this information.
Support confirmed it's a 10A fuse in the kettle lead plug!
All EU plugs must have them
This is a type G plug.
Found mainly in, United Kingdom, Ireland, Malta, Malaysia, Singapore & the Arabian Peninsula.
This cable is rated for up to 13A.
And are equipped with a glass fuse in the plug.
Mainly used in the EU are type C, E and F plugs.
This cable is suitable for a maximum of 16A.
These do not have a built-in fuse.
