uneven prints and gaps, underextrusions
tina
 tina
(@tina-2)
Hello, i have a few issues since the last 2 firmware updates, first the filament is leeking and actually i have a very inconsistent and really ugly prints. There a layer gaps and it seems on le right side he producing underextrusions? I was thinking if a warped bed, because i cant print without glue anymore, but it seems a deeper problem. I made the first layer test, picture here. Pls can someone help to fix this issue? thank you.
All parts are not wobbly or something and i changed the nozzle and cleaned the extruder in january 25...
Postato : 30/03/2025 12:50 pm
This sounds like a hardware issue.  Have you changed your nozzle recently?
Postato : 30/03/2025 8:59 pm
tina
 tina
(@tina-2)
RE: uneven prints and gaps, underextrusions
as i wrote i changed the nozzle january 25, because of the leeking and the massive print problems. the initial issue where that my prints does not stick anymore on the plate, i using glue. Second massive strings and the nozzle produces alot of "debris" while printing. and the prints are extremely uneven, as you can see in the picture...i cant practically use the printer vecause the prints looks really horrible, far away from the firstvquality when i bought the mini.
Postato : 31/03/2025 6:33 am
_KaszpiR_
(@_kaszpir_)
Check if your nozzle is properly tightened when hot, but do not overtighten.it because it may cause heat block thread getting damages and this will cause leaks or wobbling nozzle and uneven extrusion.
Please provide more details about the printer age and the components.
Postato : 31/03/2025 11:19 pm
Sorry, I wasn't clear, I meant had you changed your nozzle before the symptoms appeared?  A common cause of leakage is a wrongly installed nozzle.
Pay particular attention to the diagrams at the bottom of this page:
https://help.prusa3d.com/article/changing-replacing-the-nozzle-mini_134235
Poor adhesion is either or both of a dirty build sheet and a first layer 'Z' configuration set too high.
Postato : 01/04/2025 12:08 am
tina
 tina
(@tina-2)
The mini is 4 years old, i made in this time 2x nozzle change, heatbreak and hotend, normal maintenance like extruder cleaning, 2x firmware upgrade. all parts are original, no mods. Yesterday i squared the printer and checked the belts.  Because of the massive leekage i changed the nozzle in January after one year. But its still leeking. Tomorrow i will make a testprint again to check if the squaring and belt adjustments had any effect..
Postato : 01/04/2025 6:59 pm
_KaszpiR_
(@_kaszpir_)
did you use brass nozzles or hardened one?
Postato : 01/04/2025 7:24 pm
tina
 tina
(@tina-2)
i use the normal factory brass nozzle, i print only pla. yet another issue appears, layer desintegration, so on one side of the print the wall layer are splitted... this printer drives me crazy, a lot of issues and no idea how can i fix it...
Postato : 02/04/2025 12:58 pm
tina
 tina
(@tina-2)
Postato : 02/04/2025 1:26 pm
Please how us a picture of your nozzle/heatblock assembly from two different angles.
Postato : 04/04/2025 9:39 am
1 persone hanno apprezzato
tina
 tina
(@tina-2)
Postato : 05/04/2025 6:07 am
Not quite sharp enough to be certain but it appears that molten filament has been running down from the top of the heatblock - please check.
If so the most likely cause is a wrongly installed nozzle.
Pay particular attention to the diagrams at the bottom of this page:  https://help.prusa3d.com/article/changing-replacing-the-nozzle-mini_134235
Postato : 05/04/2025 8:38 am
_KaszpiR_
(@_kaszpir_)
Also check if the nozzle is loose when hot, if it gets loose over time after assembly this usually means damaged threads in the heat block.
In that case it would be better to replace original aluminium one with plated copper/brass. This also helps in minimizing issues with hardened steel nozzles.
Postato : 05/04/2025 11:18 am
