Turn off start cal
Mick Hanks
(@mick-hanks)
Turn off start cal
How do I turn off the 9 point cal in the start of each print?
Best Answer by Bob:
This is set in your gcode.  Go into Prusa Slicer, click on the Printer Settings tab, find "G80 ; mesh bed leveling" and remove it or comment it out by putting a semi colon in front of it.  If you want to change between mesh and no-mesh you can click the save button (floppy disk icon) and give it a new name, such as "Original Prusa Mini No Mesh".
Cheers
-Bob
Opublikowany : 23/02/2022 7:03 pm
Bob
 Bob
(@bob-2)
RE: Turn off start cal
Cheers
-Bob
Opublikowany : 23/02/2022 7:34 pm
Mick Hanks
(@mick-hanks)
thanks it was G29
Opublikowany : 23/02/2022 9:58 pm
Huh, first I was confused by the mentioning of 9 point MBL because the Mini does 16 points., but okay...
Yes, the Mini uses G29 for MBL, whereas the Mk3S uses the Prusa-specific G80 code.
Opublikowany : 24/02/2022 1:18 am
