[Solved] Stoping(pausing) prict process from gcode
Javacer
(@javacer)
Hi ewryone!
I need help with stoping from  gcode print process in my Prusha Mini. I know, what i'll can stoping prin process in current layer in prusha clicer by using "change color", byt it not good idea. I'll need stoping two or more stop and inclide in model magnets and etc.
Plese, who know write me worked GCODE for pausing prin proces and resume from stoped layer.
Best Answer by bobc:
The "M0" command should pause a print and wait for resume by user.
Posted : 24/03/2020 6:03 pm
Javacer
(@javacer)
RE: Stoping(pausing) prict process from gcode
I found it in slicer 2.2+
Posted : 24/03/2020 6:13 pm
Javacer
(@javacer)
it's not worked in prusa mini 🙁
Posted : 24/03/2020 8:47 pm
bobc
 bobc
(@bobc)
Posted : 25/03/2020 1:07 pm
Javacer
(@javacer)
Ok, thanks.
Posted : 25/03/2020 2:09 pm
bobc
 bobc
(@bobc)
Good news! There is a new version of PrusaSlicer which supports this feature 🙂
https://blog.prusaprinters.org/prusaslicer-2-2-0-is-out-hollowing-support-for-3rd-party-printers-and-more/
Posted : 26/03/2020 1:58 pm
Rick
 Rick
(@rick)
The M0 (that's M[zero]) command allows you to pause. If you do not specify any other parameters then it pauses until the user performs some action to cancel the pause. You can specify a time period for the pause in milliseconds or seconds in which case the printer pauses for that amount of time then continues. On the MK3S (and I suspect on other printers) you can click on the encoder dial to continue but that's not working on the MINI. So, it sort of works on the MINI so long as you specify a length of time to pause but you have no control beyond that.
The issue was reported on GitHub a couple of weeks ago: https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/283
Posted : 26/03/2020 6:31 pm
Javacer
(@javacer)
I finded the issue..
And so.
Torday I used M0 command with S(second timeout) for prusha (readded in gcode spec).
My code for insert balls in fishing lures:
G1 X170 Y170; move head to right side and the head not closed  the model
M0 S60; sleep to 60 second, and I insert the ball in lure(wobler)
;printer resum print automaticly
Thanks for helping! 🙂
And photo printed lure:
This post was modified 4 years ago 2 times by Javacer
Posted : 26/03/2020 7:53 pm
Rick liked
Rick
 Rick
(@rick)
@javacer
That works but it would be nice if the M0 command worked as is should. If it did then you could put in an M0 with no other parameters and it would sit there until you clicked the encoder knob. That way you don't risk missing the pause.
Posted : 26/03/2020 10:58 pm
Javacer
(@javacer)
Nope. This command in prusha mini stoped printing witout sleep time and don't continue printing after click to button...
Posted : 04/04/2020 12:26 pm
