Smoothness of surface
atomleef
(@atomleef)
I face a small rough surface problem. Is this normal, if not, how solve this issue? Please suggest.
Thank you
Ps. Please see an attachment
Respondido : 06/06/2020 7:40 am
atomleef
(@atomleef)
RE: Smoothness of surface
More image 😀
Respondido : 06/06/2020 7:43 am
Oxygen
(@oxygen)
I had 'sort of' the same issue and explained it to myself that the hotend travel path changed from a square (and possibly the seam aligned) to 2 brackets (to make the hole in the cube) (and a possibly different alignment of the seam)
Stock MK4S with FW 6.2.6
Respondido : 06/06/2020 7:55 am
1 les gusta
atomleef
(@atomleef)
@oxygen
Than you, then this is normal issue 😀
Respondido : 06/06/2020 12:56 pm
Oxygen
(@oxygen)
I do not know for sure it is my explanation for the effect we see in our prints -- maybe someone has a better answer and can correct me 🙂 or even better, has a solution for the effect...
Respondido : 06/06/2020 3:52 pm
Oxygen
(@oxygen)
looking again at you photo's your problem is at the outside of the printed object, maybe you can slower the print speed and try again (i would suggest 20% lower speed)
Respondido : 06/06/2020 3:56 pm
LuL3D
(@lul3d)
My money is on loose grub screws for the belt gear on either the X or Y axis motor. If that second picture is from the front, check the X axis first.
   ...Doug
Respondido : 06/06/2020 11:11 pm
1 les gusta
atomleef
(@atomleef)
@doug
thank you 🙂
Respondido : 09/06/2020 3:19 am
