Slicer
Ramysi
(@ramysi)
Slicer
Hi there,
I slice my 3D models with Prusa Slicer, but when I want to print it with my Prusa Mini, the printer won't recognize it. It displays the file, but says it is not suitable for the printer. When I print start, he also prints something, but most of the time it doesn't stick. It works again for the test files.
What can I change?
Opublikowany : 14/09/2022 12:06 pm
RE: Slicer
Do you have a prusa mini profile installed in Prusa Slicer and if so have you actually selected it to be used when slicing for generating the gcode ?
You cant just use any old profile, slicing using a MK3 profile for example is not suitable for a mini which is why there are some safe guards built into the firmware.
Opublikowany : 14/09/2022 1:16 pm
1 ludzie polubili
MODERATOR - Please move this thread to a more appropriate forum.
@schneider-rahel:  I guess there's more than one issue here.
First check: You do have Prusa Mini selected in the dropdown in the right hand pane?
If so then save your project as a .3mf file
Files > Save Project as
Opublikowany : 14/09/2022 1:20 pm
Ramysi
(@ramysi)
RE: Slicer
sorry for answering so late. Thanks for the answer. I didn’t selected mini, but it took a while till I realized it 🤦🏼‍♀️
Opublikowany : 29/11/2022 6:53 am
